跳转到主内容
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 个问题 查看全部
Upgrading to latest Android version manually
Hi there, I have an old Samsung Galaxy Tab 2 10.1 with Android version 4.0.4. Nothing is compatible with it anymore. How can I upgrade it to the latest Android version please? I have checked and it says no updates available
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 40
7条评论
Thank you so much
完成的
Yes, you can upgrade to Android 6 Lineage 13.0, I have Samsung tab 2 10.1 with that
完成的
Thank you so much Stephen. Much appreciated. How did you upgrade please?
完成的
I have samsung tab 2 and playstore dont want to work
完成的
I too have a Samsung Galaxy S - model number SM-T800 - running Android 6.0.1
When I check the updates it says it is up to date.
I would like to download an Application - Imaging Edge Mobile from Sony, so that I can check photos and videos taken on my Sony camera HX60V - It says the software is not compatible and I require Android version 7 at least to install the software.
How can I update the Android Version on my tablet?
完成的
显示更多的2条评论
添加一条评论
3个答案
已选择的解决方案
here you go
you need to install a custom rom
Android is modified by the manufacturer to work on their device, because every device has different hardware.
https://www.youtube.com/watch?v=7V5tZi5V...
这个答案有帮助吗?
得分 8
4条评论:
I have two Tab 2's - both at now too slow to use. Wanted to see if there was a way to update. the link above is marked Private.
完成的
This was rubbish. The video whizzed through so fast and without explanation so that it was impossible to follow.
完成的
the video has gone private
完成的
As others have said, the video is private.
完成的
添加一条评论
If you go to [http:// https://forum.xda-developers.com/t/how-t...|XDA’s website] by clicking the link it should bring you directly to the how to’s of the tab 2. there is all kinds of valuable info on this site and if utilized will hopefully give you a better understanding of your gadgets. Good luck!
这个答案有帮助吗?
得分 3
1条评论:
Thank you William. That link was incredibly helpful!
完成的
添加一条评论
Try googling (samsung android tab 2 update ) and it will tell you how and where to go
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jackie Barton 将永远感激不已
浏览统计数据:
过去 24 小时: 24
过去 7 天: 212
过去 30 天: 1,049
总计 71,094
