跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Can I use bootcamp with an SSD in my optical bay?
I have an Early 2011 Macbook Pro 15” 2.2 Ghz model
I have my original HDD in its original spot
I have a Crucial SSD in a mount seated where my optical drive used to be.
I have all of my Windows 10 install files ready to go on a flash drive
I love the boot speed from the SSD, and I love the storage on my drive. What I want is to partition my SSD to boot both my OSX and my Windows.
When I try to use Bootcamp to partition the SSD, it tells me I can’t do so without my optical drive, even though I have all of the windows install files on a flash drive which Bootcamp itself set up.
Do I have any options here, without moving my hard drives around again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly no, this will likely not work ;-{
First the optical bay has a speed issue. Review this OWC Data Doubler you’ll see your system has a Red note. The issue is not the carrier, it’s the systems optical drives SATA port. So you’ll need to get a fixed SATA II (3.0 Gb/s) most SSD’s sold today are either fixed SATA III (6.0 Gb/s) or auto sense which allows them to work in either a SATA I, II or III system. This is where the auto sense logic wont work correctly as the system will confuse it.
Now you have a second issue if you decide to swap the drives around as the HD bay’s port has additional logic to protect the HDD from a head crash (Crash Guard) so you then put your HD’s data at risk.
Then you have an issue with BootCamp as it must be on the Boot Drive.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Trevor Romney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 292
