跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
iPhone 7 Plus won’t power on.
It was any other day. I went to go get my phone and it didn’t power on. I let it charge overnight and in the morning it would power on. I went to a repair shop and they said that the home button came displaced and to take it to Apple. It doesn’t have any sort of warranty. I feel like the home button thing is BS. Would it be the battery? Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Lithium Ion batteries typically last about a year and a half before they start drastically degrading. BUT that also varies on your charging habits, so id check for a dirty charge port, but I would for sure change the battery. if they are the FIRST people to open it and they say your home button is torn then they tore it getting into the adhesive of the phone and technically (if you can prove it) owe you a new phone because your touch id will not work again due to it being paired at the factory with your board IC
这个答案有帮助吗?
得分 0
添加一条评论
From my research on the topic, the home button thing probably was BS, and it might be a battery issue. You can go to a repair shop and get it fixed for less than 100$
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Owen Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 173
