跳转到主内容
加入维修社区 - 创建账户
发布于 2016 年 8 月,型号为 XAV-AX100 车载影音接收器。
Power surge to volume
Whenever I open the door, step on the accelerator, or connect to the bluetooth. The volume goes to Max all by itself. Also if I just have it on for awhile it will do it I have rewired outside checked relays in grounds in the vehicle. Also replace fuses, Any other ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try removing all the radio's connections except the main wiring harness. If the problems stops, then it's likely an issue with one of the other connections such as the wired remote input. The Sony XAV-AX100 has a wired remote input intended for steering wheel control and it's possible that connection is acting wonky. Loose or incorrect connections at other inputs such as Sirius, mute, mic, remote turn-on, etc. can cause the radio to act weird. Take a look at the buttons on the faceplate and the remote to see if any are stuck or jammed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Symmes 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 313
