跳转到主内容
The Chevrolet Blazer (and its cousin, the GMC Jimmy) can refer to one of several SUV models produced by General Motors including the Chevrolet K5 Blazer, Chevrolet S-10 Blazer, Chevrolet TrailBlazer, Chevrolet Tahoe, and Chevrolet Blazer.
38 个问题 查看全部
When my headlights turn on at night dashlights go out
When my auto lights turn on at night my dashlights my radio and the temp gauge above all go out black. Its a 99 chevy blazer I have done tons on internt research seems like happends alot but noone gives a straight answer to how they fixed it please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you sure you don’t have the dash lights dimmed all the way to the off position? On the left side of the dash next to the headlight switch there should be a gray wheel you can rotate up for brighter dash lights or down to dim or turn off the dash lights. If you rotate it up until it clicks the interior dome light will come on. Try rotating that wheel at night time with your headlights on and see if they work after that. If not you have to check the dash light fuse. Reply if it does not work and I will see if I have another answer for you.
这个答案有帮助吗?
得分 0
1条评论:
Problem has not been solved
完成的
添加一条评论
添加你的答案
Nicole Summa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 185
