跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Vizio D65u-D2 works on standard picture set to medium, not on vivid
Vizio D65u-D2 turned the setting to standard and medium. Picture loss issue resolved. If I set picture to Vivid, lose picture after a 5 to 10 minutes with audio only. Turn off, turn on, issue repeats. Ordered the power supply board to see if it allows me to use Vivid setting without loss of image. If after change issue continues, what is best bet for next board to change?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
vivid mode might be over driving the backlight
这个答案有帮助吗?
得分 0
添加一条评论
Did you ever figure this out? Having Same issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pistolstar4 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 179
