跳转到主内容
Touch screen recognizing finger only s pen on note 9
I was replacing a screen on a note 9 and when I switched the motherboard and other components to the new screen and powered it on the phone would not recognize me touching it with my finger so I tried the s pen and it worked fine so then I switched everything back to the old screen thinking that it was just a defective part and it still wasn't working. I tried cleaning off the connectors for the screen and resetting the phone and neither worked. Any help would be greatly appreciated. Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I thought so too but I put all the components back onto the original screen and the touchscreen didn't work on there anymore and I also tried different screen and didn't work on there either
完成的
添加一条评论
2个答案
最有帮助的答案
probably just a faulty screen
S pen is a completely different part of the display to the digitizer, it’s the large rectangle flex near the lcd connector.
unless you buy the screen from samsung or from a new phone they are all refurbished, so probably just a dud screen
这个答案有帮助吗?
得分 1
添加一条评论
Did you ever get this fix? I'm having the same
这个答案有帮助吗?
得分 0
1条评论:
Also, would something like that be under warranty?
完成的
添加一条评论
添加你的答案
Poop mcgee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 2,457
