跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
Screen comes on for nano second then goes off again
I have replaced the screen a couple of times. The first time I thought it was a dodgy screen so I ordered another and it does the exact same thing. When I press either the power or the home button the home screen appears for a nano second then goes off? Tried reboot via iTunes etc but nothing. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
If you hold a flashlight on the screen, can you see a faint image? If so, it’s your backlight ic going out.
这个答案有帮助吗?
得分 0
1条评论:
That’s great I’ll check it. Thank you
完成的
添加一条评论
Hi,
when you replaced the screen did you desolder the sleep magnetic induction flex and transfer to your new display,
if not this will be the main cause for your problems.
A image of the flex is attached. It’s located at the bottom of the lcd
这个答案有帮助吗?
得分 0
添加一条评论
Is it this one?
这个答案有帮助吗?
得分 0
4条评论:
Yes that’s the place where the flex needs soldering back to
完成的
Hi I’ve added a video if you have any ideas id really appreciate it
完成的
Hi, sorry for the delay been mad busy in work lately. Are you up based ? If you are I would be more than happy to help you out with this.
完成的
Also have you gotta picture of the screen with the new flex attached?
完成的
添加一条评论
Ok tried this. Bought new part and soldered it on. I’m still getting a nano flash of the screen then nothing…. help?? It’s had new lcd digitizer screen and new flex cable but still the same problem. I can press either the power button or the home button and get the same thing. It’s driving me crazy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Debbie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 83
