跳转到主内容
加入维修社区 - 创建账户
The third iteration of the 10.1 inch Galaxy Tab tablet.
Broken cable clamp on Orange flat cable
After replacing the battery on my 10.1” galaxy tab 3, the little bar clamp on the orange cable broke and the cable does not clamp down in the slot. Swiping the screen is now erratic and often not even happening. I guess this is the problem as I have changed the battery before with no ill effects. Is it repairable?
Holding the cable in place with tape does not help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Can you add a photo
完成的
Thanks for your quick response Daniel, can't seem to paste the copied photo. if its any help the little bar was a brown colour and snapped in the middle and both parts disappeared.
If you know how to post the picture I have it.
完成的
You can edit the post and add a photo. Click on options and edit
完成的
Sorry Daniel this isn't working for me. I'll report back after the white tak attempt
完成的
https://www.dropbox.com/sh/axs768psmbm9m...
I have dropped the photo into here, hope it helps because the white tak solution has not performed
完成的
添加一条评论
1个答案
已选择的解决方案
im guessing its this you mean dennis. yes they can be repaired but you need the proper tools to replace it. i have only done 1 on a tab e before
这个答案有帮助吗?
得分 2
13条评论:
looks like that. I am not hopeful for a good outcome.
It is taking a long time to charge now and as it is over 6 years old I feel it's race may be almost run......
完成的
the charging issue could be a bad charge port or the charging chip is going bad
完成的
Are the parts easily obtainable?if so from where? it couldn't hurt to change the charging slot and maybe all the flat cables.
完成的
should be available on ebay
完成的
Cheers Daniel, I will report back any success
完成的
显示更多的8条评论
添加一条评论
添加你的答案
Dennis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 932
