跳转到主内容
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
59 个问题 查看全部
Screen flashes purple everytime I turn phone on and flickers white
Everytime i press the side button to turn my phone on the full screen flashes purple and doesnt respond, it does that for like 3+ minutes everytime i press it and then decides to want to work until the screen goes off and it does it again.
ontop of that, when my brightness is low it flickers white and the longer its on low the worse it gets.
if its slightly brighter it works completely fine and i have no other issues with my phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you got the firmware anywhere? And then the behavior is typical for this problem.
这个答案有帮助吗?
得分 0
添加一条评论
I did everything, reset, factory reset. I did a cache delete then reboot. Nothing worked. I turned off battery saver. I heard it was something do with power not getting properly to the display. Then I thought hey I just recently turned on biometrics for fingerprint unlock . I turned off EVERYTHING to do with finger print scanner and biometrics. Haven't had a problem since! Hope this helps. Try everything before getting new screen!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
idek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 819
