跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
197 个问题 查看全部
I replaced my apple watch series 3 screen now screen not lighting up
hello i replaced my apple watch series 3 screen and now the screen will not light up its blank but when i charge it its on because i hear the charging sound i dont know what to do please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Have you tried reseating the display connection?
完成的
when you mean reseating what do you mean by that? thank you and have a nice day
完成的
Reconnecting the connections
完成的
添加一条评论
2个答案
Did your old screen work before repair or was it blacked out? If it worked, try your old screen. If your old screen works, then double check that all the connectors are seated properly. On the series 3 those three connectors can be tricky to get pushed all the way up into their socket.
这个答案有帮助吗?
得分 0
2条评论:
thank you i did both already i reconnceted my old screen its blank also i dont know if i did something wrong or i maybe burned both screen if thats possible but thank you again for the advice.
完成的
Youre welcome. Hopefully there is no damage to the board in the watch. Maybe try another screen just for verification and if the issue persists then its a board level problem.
完成的
添加一条评论
Did you ever get your Apple Watch working after replacing the screen?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KING AZTEC 32 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 238
