跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
What kind of adhesive do I need to repair my wifi-card?
I’m having issues with my WiFi connection which I’m pretty sure has to do with my WiFi card. I just did a test to open it up and look at it to see if it was just loose before I spent the money on another WiFi card. After peeling back the tape on the iSight cable and the Wifi card, the adhesive is still working but is a bit loose. If I peel it back again, I may need new adhesive.
So my questions are:
  1. What kind of tape is used on the iSight cable?
  2. What kind of tape is used on the WiFi card?
The tape on the iSight cable is noticeably thinner and not as “grippy”. Is it gorilla tape? Electrical tape?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Before you replace your AirPort board how about just replacing the cable MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable More often I find the cable fails than the AirPort board.
As far as the tape: I use Black duck tape over the AirPort board and over the iSight camera connection on the logic board. You can also use Polyimide Tape as well.
Polyimide Tape图片
产品
Polyimide Tape
$9.99
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable图片
产品
$29.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 101
