跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
3.0 diesel to SBC engine swap
  • I'm probably going to get some grief over this, but I'm swapping the 3.0 diesel in an 81 300D for a 350. I'd like to have a clean engine bay (no exposed wires and such). I'm down to 3 pieces that I'm unsure of. 1: the resistor pack on the passenger firewall 2: a small electrical box at the uppermost drivers wheel well and 3: a smaller electrical box on the drivers wheel well just below the cruise control canister. Do these control body electrical or engine electrical?
Update (01/20/2019)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try searching all the control blocks/electrical boxes on google! Should tell you what is it and what is its mission in your car! If you can’t find anything by the box numbers than just follow the wires and see where they are going from the box and it should give you an idea of what is it for.
Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Thank you Andromm. That's what I ended up doing for all 3.
完成的
添加一条评论
添加你的答案
joshuaahopkins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 163
