跳转到主内容
加入维修社区 - 创建账户
Mercedes-Benz 204 系列是中型车型 C-Class 的一个系列。该系列于 2007 年 3 月至 2015 年 6 月期间生产,取代了自 2000 年 3 月起生产的 203 系列。 轿车版的生产于 2014 年 5 月初结束。其继任车型 Mercedes-Benz 205 系列自 2014 年 2 月初开始生产。旅行车 (T-Modell) 的生产于 2014 年 3 月停止。作为该系列最后一款车型,轿跑车 (Coupé) 的生产一直持续到 2015 年 6 月。
Repair mercedes sam module at pc shop?
Actually i have an 07 mb e350, w211 body type, wasn't listed in drop down box. Trunk got wet and fried sam module/ signal acquisition module. This controls all car functions and are 3 of these which are connected to a fuse box on each. Can a pc repair shop do this repair. If the original from the car is repaired there is no need for any programming from a mb shop with the star diagnostic system. There are shops that do this but none near me. Also i believe at least 2 of the 3 of the sam modules have been affected. The other not by water but an improper battery change. Excessive arcing when connecting or disconnecting battery is apparently another main cause. My systems are all showing the tell tale signs, dash buttons and radio not working, system malfunctions on multiple systems etc. So would it be ok to ask a pc repair shop to perform this. I read a 64 pin, chip is the root of all this and bad design. Its just a computer board. Not a pc but i assume all the same components go into most circuit boards. Thank you. New sam units are expensive and still need programming, used would work if from exact same model but still need programming. Also most come from totalled vehicles which could have the same problem. Thanks, John.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi there!
If the PC repair shop has some normal people woking there they should be more than pleased to help you out with the SAM module. Not saying that they will fix it 100% but they at least can tell if the module is repairable. But if some water got in there that should just be a matter of soldering, cleaning and testing. I work in a PC repair shop and we do those kinds of things as well. Mainly because I have a car electric diploma :D!
Hope this helps!
这个答案有帮助吗?
得分 3
2条评论:
What is the work of back Sam Mercedes Benz
完成的
@aluma Hey! Sorry for the very very late answer XD! SAM module controls all the rear electrical assembly... that is lights, door locks, sensors ext.
Hope this helps :)
完成的
添加一条评论
添加你的答案
John Bradley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 47
总计 4,818
