跳转到主内容
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
97 个问题 查看全部
Wont turn on or charge
I just bought a JBL xtreme 2 weeks ago and i have had zero problems with it, until today when i went to turn it on. It wont turn on anymore, with or without the charger (original charger from box) it wont turn on, the lights are not turning on, it doesnt react to any buttons pressed. The only thing that is working is that i can charge my phone through the usb port , please help :’(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
I have the same issue too, tried to factory reset but it didn't even turn on a single led.
这个答案有帮助吗?
得分 0
添加一条评论
have you found any solutions? I have the same problem
这个答案有帮助吗?
得分 0
添加一条评论
Estava pesquisando num representante de reparos e verifiquei que as Xtreme/Boombox queimam mosfets de potência quando usados em volume alto durante a recarga. Esse excesso de corrente causa a queima dos semicondutores e provocam o problema.
Estou buscando o esquema elétrico para verificar quais mosfets são estes e como posso usar equivalentes com potência maior.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
viccecool 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 399
