跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
A1418 stuck on chime loop after disk replacement
Hi Everyone,
I’ve replaced the HDD on my Late 2013 21.5” iMac A1418 (EMC 2638).
After installing the new HDD the iMac on power up showed the folder with question mark, I’ve inserted USB with High Sierra 10.13 created with TransMac after started install it showed Apple logo and was stuck 10minutes, I’ve pressed the power button, after power up again the iMac is stuck on chime reboot (5 sec) tried to boot in Safe Mode, tried PRAM reset (pressing the Option, Command & P + R keys before pressing power button) any ideas?
Best Regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What drive did you put in? Make & Model.
完成的
I put in a SanDisk SSD it recognized it correctly and displayed folder with question mark (no system found on SSD).
完成的
添加一条评论
2个答案
OK, so you swapped the HDD with a new formatted one. Assuming this drive is in perfect condition and correctly connected, The reason why after the chime (the sound) the folder with the question mark shows up is because the system does not find a bootable drive (I think EFI doesn’t have set up to boot from USB drives by default).
So It’s most likely that you don’t boot from the USB drive or even that USB bootable copy was not correctly made.
Try to start up with the drive attached and pressing and holding the Option (⌥) key immediately upon hearing the startup chime. Release the key when the StartupManager appears, showing you two possible options: your internal HDD and the install USB drive.
Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the advice, the computer doesn’t go past chime sound. I cannot select anything as its in 5 second chime loop.
完成的
添加一条评论
Lets try this, Instead of booting up under the USB thumb drive or using OptionCommand & P + R.
Lets use the built-in Internet recovery service again.
With your system connected to the internet (Ethernet or WiFi) follow this Apple T/N Reinstall from macOS Recovery.
This time lets just run Command (⌘)-R
这个答案有帮助吗?
得分 0
2条评论:
Ive tried pressing all combinations as said as my description of trouble together with the keys you said. Tried with hdd, with usb, without all. Wired wireless keyboards all also tried still chime reboot 5sek
完成的
If thats the case then you have to go back to your original HDD to see if the system still works with it. I'm suspecting something got messed up in your upgrade process.
完成的
添加一条评论
添加你的答案
Dr. Apple 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 141
