跳转到主内容
Why won't my MacBook Pro boot after replacing the motherboard?
I just replaced the motherboard in my Mid 2009 13” unibody macbook pro. It all seemed to go very well, then I turned it on. The machine powers up but all i get is a white screen. No boot. Any ideas on what may be the cause?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Does the external display show your desktop or blinking ? folder?
完成的
The display is just a white screen. It powers up no problem and you can here their initial tone but then nothing but a white screen.
完成的
Thats from your internal display, now hook up an external TV or monitor what does it show?
完成的
Nothing. The monitor doesn’t pick up a signal from the laptop.
完成的
Have you experience with replacing logic boards?
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
Other than review your connections I would say the logic board you got is bad. You’ll need to return it to get either a replacement or your money back.
这个答案有帮助吗?
得分 1
1条评论:
You were right Dan. Was the connections.
完成的
添加一条评论
添加你的答案
Michael Detroyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 164
