Is something wrong with my ipod battery?
my ipod classic model A1059 has a folder with an exclamation mark on it what could be the reason for that. it also want show up in my itunes.
First, reset and restore, as bac suggested.
After that, you're looking at a hard drive or hard drive cable issue.
One of the best methods to diagnose a failing hard drive is to listen to the drive. If you put your iPod up to your ear, you should hear a smooth-sounding whirr of the hard drive spinning. Any loud clicking or grinding sounds may mean that your iPod's drive is failing. If you don't hear anything, the drive is not getting power or is very damaged and can't spin up. In this instance, replacing the hard drive cable first is a good idea. Then, if the problem persists, replace the hard drive. Browse our hard drives and check out our iPod ID page for compatible drives.
Good luck!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,984
1条评论
FYI: A1059 corresponds to a 4th Gen iPod, not a Classic.
由 Ben Eisenman 完成的
