跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
How to get my data from hdd?
Hello,
I have MacBook Pro 2011 and after the logic board problem I can't log to my MBP ! I have very important data on it!
Now I have a PC with windows 10 how I can get my data again ?
Note: The MBP had a password when it's work properly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
This just make internal hard disk as external hdd I have tool like this.
The problem is: I can't see my files in hdd Because the OS is different.
Thank you for answer.
完成的
Hi @aligraphics ,
There's info online that shows how to read mac files using Windows. ;-)
完成的
Thank you so much, I made it before this but I can't see my data only system files exist!
完成的
Hi @aligraphics .
You can try this and see if it works. It says that there is a free 5 day trial before you have to buy it ;-)
完成的
添加一条评论
1个答案
已选择的解决方案
Buy the enclosure here and transfer your MacBook Pros hard drive into the enclosure. Plug the enclosure into your new computer and you can retrieve the files thru there.
https://www.amazon.com/AmazonBasics-2-5-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 111
