跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Why is my iPhone 6s screen only displaying a few seconds aft restart?
I just replaced the screen and the battery to no avail. I was having issues getting the charging port to work originally(few days before), then it did this. After hard reset the screen comes up then disappears a few moments later, no indicator as to why. I noticed once it went off when the raise to activate turned on so I turned that off, still has the same issue. Also weird I don’t see a boot logo. My phone wasn’t turning on at all until I noticed the connector next to the battery came loose. I only see two water sensor stickers and neither are colored nor do I have a reason to suspect water damage. Thanks for any ideas, theories, or assistance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try booting up the phone without the front camera and home button cable plugged in, sometimes a bad home button / front camera can cause this.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, tried it, but no luck
完成的
添加一条评论
you may try to put a new battery to test again if the problem still happens probably it is motherboard issue on your phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jo kn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 43
