Is this a good combo for gaming?
Hi, I have a Dell Precision T1500 and I was wondering if an AMD Radeon HD 6770 GPU and an Intel Core i7 860 CPU is a good combo for gaming. I mostly play Fortnite and sometimes Warface.
Thanks in Advance!
No, the 6770 is a very low end card. Those games might be playable, but the framerate they will run at (20-30 fps on low at 1080p) will be very distracting.
这个答案有帮助吗?
As Ian stated earlier, a higher end GPU would be required to play at what many people would call playable (40-45fps @ 1080p. Another factor to consider is the CPU. Whilst your i7 860 is still holding its ground for now, it is a 10 year old processor, and may not be able to play the games you want in the near future. Using this CPU with a higher end GPU may work for the time being, however, I would be starting to look at newer options.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 374
4条评论
If you can . Go get a Gt 1030 with ddr5 memory. you will be able to run fortnite at low 1080p with 60fps. cheers
由 plgraveline22 完成的
Greetings. Well I just finished a build which is a Ryzen 5 1600 and a GTX 1660. I appreciate your help though
由 Random _User_101 完成的
hey i just need to know how much fps ill get with either a nvidia gt 710 or a nvidia quadro 600 with an intel core i7 860
由 eli 完成的
What games will you be playing?
