跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
How to test the battery pack before replacing it?
I have a dead Surface Pro3, presumably with a defective battery pack. After many months of looking at it I took the plunge, broke through the screen and have the battery tail with its connector free. The main connector tabs show zero volts but Im not sure if this indicated a dead cell or that I am not enabling a switch within the battery management scheme which is part of the battery pack.
Can anyone tell me if the battery tail should be at 7.5V standalone, ie how do I test the battery pack before trying to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
In Windows 10 you can open a command prompt with admin priv and type powercfg /batteryreport /output "C:\battery_report.html
这个答案有帮助吗?
得分 0
添加一条评论
no directly replace it, without doing any test, as you already said the battery is dead so there is no reason to test it, a dead battery could also harm your surface pc , so be cautious.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Nicols 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 209
