跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Customer says phone sometimes won’t charge?
So I got this phone and they told me it sometimes won’t charge, so to change the charge port. When I first got the phone sometimes it wouldn’t charge, I took the battery out and it’s not doing that anymore but I’m hesistant to send it back until I have tested the charge port. How do i test for a faulty charge port if the phone is completely charging? If I send it back I’m hoping it won’t return to not charging when they get the phone back.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The battery is the weakest link so by changing the battery and the phone now charges correctly, you probably have solved the problem completely. You could try to overlay a replacement charge port (no need to do a full install) to see if that makes any difference.
Intermittent problems are always the worst kind of problem and the only way to know for certain is to give it time. Either let the customer try it out, under the expectation that it may come back, or have the customer leave the device with you for a few days so you can test it under several charge cycles.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jesus flores 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 58
