跳转到主内容
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
38 个问题 查看全部
My headphones are in the wrong direction.
My friend broke my headphones and the little piece that goes inside your ear came off so he super glued it but he glued it the wrong way. It doesn't come off anymore can I do something to remove it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You can usually use nail-polish remover to get superglue off, you can also try Goo-Gone, but I’ve had better luck with nail-polish remover.
这个答案有帮助吗?
得分 2
2条评论:
The glue is on the inside. So I can't really take it off.
完成的
You can put nail-polish remover inside, you just need to clean it afterwards with alcohol and let it dry completely.
完成的
添加一条评论
添加你的答案
Rudolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
