跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
6S+ Camera not working after replacing it.
My 6s+ was plagued with the shaky tracking issue everyone else has.
I bought a replacement and installed it. Now flash/led does not work and the camera is not recognized by any app. (Black screen). I reopened the phone and reinserted the OEM one… same issue. All connections are tight and everything is replaced as it should be.
I’ve reseated the ribbons 10 times (which each camera, old and new) and restored my phone to factory. No change.
Did I damage the board? I’ve seen a ton of these questions asked but the answers are always “reboot the phone” “reseat the cables”. That’s not the answer here.
What’s my next move?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Unfortunately, it does sound like the board connections have been damaged in some way. Either replace the board, or upgrade your phone is probably your best option. If you already attempted a restore and it did nothing, thats probably the issue.
完成的
添加一条评论
1个答案
If reseting the cables didn’t work, I think the next step would be a new front assembly. Thats the proximity sensor, mic, speaker, and camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tdog69697 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 45
