跳转到主内容
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
35 个问题 查看全部
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Probably needs the digitizer cable reset. OnePlus 5T Teardown here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
这个答案有帮助吗?
得分 0
添加一条评论
Original screen folder Amoled
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam Mooney 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,573
