跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,新 Nintendo 2DS XL 是 Nintendo 2DS 掌上游戏机的迭代机型。
My device doesn't start...
I’ve repaired the Nintendo 2ds xl top screen, because it was damaged.
Now if i want to turn on my device, the blue light turns on for about 4 seconds, both of the displays are flashing and then the blue light and both of the screens turns off :(
What can be the reason?
I’ve thought it can be the battery, changed it and the same issue is happening..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
Check the ribbon cable connection of the displays. If those are not seated properly or if the cables themselves are a bit damaged (scuffed or dented), the console won't turn on.
这个答案有帮助吗?
得分 2
4条评论:
But if the ribbon cable connection of the displays are not seated proberly, will both displays flash up then?
完成的
Hi!
Yes, a bad connection does not mean that there isn't any connection, it just means that it's not enough to get a good enough signal trough.
It's honestly a dumb feature implemented by Nintendo to have the consoles check the hardware upon boot and shutdown if anything is wrong.
完成的
can it also be a broken mainboard?
A shot smd or similar?
Or is it a pretty clear sign of no good connection?
完成的
To me it's a pretty clear sign of a bad connection. The chances that you broke the main board while replacing the display are quite low.
完成的
添加一条评论
添加你的答案
Michael D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 444
