跳转到主内容
The Dell Venue 11 Pro is a flexible slate tablet built for business. It comes with many work-oriented features, including Windows 8.1, a removable battery, and a variety of docking solutions.
11 个问题 查看全部
Device Will not charge or turn on.
I bought this tablet used. When I first bought it, it worked fine then the battery drained. Bought a new charger from eBay that is made for dell venue. It would not charge. tried 3 known good batteries even tried a new dell from Amazon. I’ll plug it in and the white light comes on and off again randomly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If the Dell laptop does not turn on with either the power adapter or the battery then the mother board has probably failed. You can try removing the bottom cover and removing the CMOS battery for 10 minutes and then reconnect the CMOS battery to see if this will let the laptop start. Another common problem is the computer starts but the display is blank, that could be either the display or the mother board.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the info. The device was functioning fine before the battery died. Dell diagnostics confirmed bad battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chrisellis87 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 20
总计 499
