跳转到主内容
Released October 2014, rectangular mobile speaker with Bowers & Wilkins on the front and back.
2 个问题 查看全部
Why is my T7 stuck in service mode?
Recently while trying to remedy what I thought was a pairing issue i used the Bowers & Wilkins Bluetooth Utility\1.2.2\Bowers & Wilkins Bluetooth Utility.exe". I thought I was doing the right thing and used the utility to clear the paired list. Now my T7 is stuck in what i’m told is “Service Mode” and i cannot release it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's a really simple fix:
  1. Plug the speaker into your pc using the micro usb (labelled service) port on the back of the speaker
  2. On the Bowers and Wilkins firmware update software (free to download from the bowers and wilkins website)
  3. If the speaker shows up on the software, click 'eject speaker' on the bottom left, this sets it back to the default mode and it should work perfectly from this point.
  4. If the speaker didn't show up on the software, try unplugging it and plugging it back in. Note that the speaker must be turned on in order to be detected. If this still doesn't work, try restarting your pc and trying again. Otherwise contact Bowers and Wilkins support.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Duckworth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 659
