跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
My screen is unresponsive.
I recently got a repair on my phone and after it was continuing to function normally. A couple months after I received a black fade at the top right corner. Then when I attempted unlocking my phone it wouldn’t cooperate. I’d have to press my power button locking it continuously until my phone cooperated. The problem has gotten worse. I’ve tried hard resetting it, factory resetting it, and resetting all the settings.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
More than likely you have a failing screen. If the company who repaired your phone has a decent warranty (6 months or a year) then should be able to get it replaced for free as long as there is no damage to the screen. If that is not the case, youll have to get it repaired again. There are instances where board level issues can cause the behaviors that you have, but more than likely it’s the screen that’s failing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Laurel Finch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 69
