跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why won’t my phone charge
My phone have been dying to quick and it wouldn’t stay charge. Before I would have to wiggle it In a way for it to charge now it doesn’t even charge at all. I thought it was probably my port so I took it to a place today and they told me it was my battery. He said my port was fine and that my battery was messed up. So I got a new battery thinking everything would be fine until later on when my phone was starting to die out, when I tired to charge my phone in my car it wouldn’t work. I even bought a whole new charger thinking it was probably the problem but it still won’t charge my phone. Idk what else to do. And idek what the problem is now
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
While it’s possibly the charge circuit, as Akash suggests, I am a little bit concerned about the diagnostic the shop/tech gave you. I mean, what kind of shop would say the issue is the battery, replace it and not even test it to see if the battery charges properly. The other concern I have is the “wiggle” you say the charge port has. Finally, using cheap car chargers can cause a lot of damage to the charge circuit.
My suggestion would be to find a better shop and have them take a proper look at phone. If you want to try things yourself, than here are my recommendations (you’ve already tried a few of these):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire phone and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port.
  5. If a new battery and charge port still don't resolve the issue, then you either have faulty replacement parts (possible) or a logic board issue. There is an IC (commonly referred to as Tristar) responsible for communicating with the charging device and uncertified chargers can damage it. Unplug the battery and connect a known-good (preferably Apple original or MFi) charger to the phone. A properly working phone will show an Apple logo and boot loop. If the Tristar IC is bad then the phone will not do anything.
这个答案有帮助吗?
得分 2
添加一条评论
After seeing all this symptoms that is the fault of U2 chip that needs to be replaced.
这个答案有帮助吗?
得分 1
1条评论:
thank you. how much would it be to fixed it
完成的
添加一条评论
添加你的答案
sabrina louis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 75
