跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Boot loop after swollen battery replacement, 4013 error
Phone: iPhone 6
Cable: genuine Apple cable
Charge brick: genuine Apple
Swollen Battery: iFixit battery, less than a year old
Replacement Battery: iFixit battery
I realize this issue is documented and answered in places. but felt my situation does not perfectly match those, and needed more answers.
What happened: I started noticing the battery swelling and pushing the screen up about 4 weeks ago, mid December 2018. The phone was crashing when it wanted. What I found to stabilize it was having it plugged into an Anker power block at all times. Needing my phone for, well, everything, I ordered the replacement battery, and kept it plugged into the Anker for stability. The phone was actually working and stable with the Anker life support system it was on.
I received the replacement battery, performed the surgery according to instructions. I have moderate expertise with small electronics, been fixing them off and on for years.
When I went to power the phone up, it was stuck in an endless boot loop of the Apple logo. I need to get into the phone pretty badly for data on it, data that was fresh from the last backup - holiday pictures, notes, etc.
Went back to the swollen battery, with Anker, same thing.
So, I got it to go to recovery mode, hoping to do the update option, so that the data would be preserved. When I plug it into iTunes, it gets ready to engage the phone, but the phone just enters the boot loop over and over and won’t allow the update. or anything else.
Any insights and help are much appreciated.
Eric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Such error actually happen while on Nand data is crashed due to some region.So need to reprogram the NAND with valid info by Nand programmer.
这个答案有帮助吗?
得分 2
4条评论:
Thanks Akash. will you please break this down for a newbie?
完成的
This process is as complex to do without special equipment and knowledge.If not contact the technician may help you to fix.Search on ifixit by this topic brother.
完成的
Thank you Akash!
完成的
In short data is going to be lost to fix the phone. I see bad batteries a lot corrupt firmware and user data on the phone.
If you tried doing an update via 3uTools usually it shows error -26/-27 for corrupt file system in that case you'll need to restore the phone.
完成的
添加一条评论
Did you solve this ? I’m having the exact same problem
这个答案有帮助吗?
得分 0
添加一条评论
I was told it wasn’t possible by one outfit. Then another told me they would try, assess it. I didn’t follow through at the time, and then the virus hit. Still have phone and might send it out. Not a priority right now.
good luck.
这个答案有帮助吗?
得分 0
1条评论:
thanks for the quick answer. I'll try to fix mine, but seems it won't be easy. In the meantime if I find a solution, I'll reach out to you.
完成的
添加一条评论
添加你的答案
Eric Carlsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 430
