跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
WiFi connectivity flopped - Why?
My WiFi has flopped all of a sudden
I tried to connect to the Internet with my cellular phone it also it did not connect, after sometime it did connect on it is own.
This has happened to me number of times over the past 2 months. Is it hardware issue or an issue related to operating system.
The nearest service centre is 500 kms away from the place where I live.
WiFi does not get recognized.
Kindly help me,
Narayanan Lakshmanan from India
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You’ll need to get a bit more diagnostic info to figure out whats happening. Go to the Apple store and get WiFi Explorer Lite so you can see your WiFi network as well as competing networks.
You may need to manually set your WiFi network to a different band as the one you are using maybe congested by others.
这个答案有帮助吗?
得分 2
3条评论:
This Wifi is an exclusive one it is not meant for public and I use it at home
完成的
This has nothing to do with access to your WiFi AP by others.
Think of it this way you are in a room and you are talking to a friend in the room you have not issues talking.
Now you turn on the TV and the radio, the oven timer is going off as well as the smoke detector from the burnt meal, your baby is crying and the door bell is ringing it would be hard to have the same dialog with all of that noise.
That's the issue here! It's not people listening in to your communication, it's the air waves that are so jammed up with others also trying to get to their WiFi AP which is sitting on the same bands yours is.
Install the app I pointed you to and lets see what it tells us.
完成的
Thank you I have understood the concept and I have installed the app I will post you with the information.
完成的
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 70
