跳转到主内容
加入维修社区 - 创建账户
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Why my Barista start dripping the espresso very slowly out
It stopped pouring the espresso like used to be now is just dripping very slowly. It took me 10 minutes to make a single shot of espresso this morning. I love that coffee machine i been having it from 10 years.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You're most likely looking at one or a combination of these issues:
- Coffee ground too fine
- Coffee tamped too hard in the basket
- Brew screen clogged
- Portafilter clogged
Does water flow through easily with the portafilter removed from the machine? Then your screen is probably fine. Does water flow through the portafilter easily when there's no coffee in it? Then your portafilter is probably ok. You're then looking at a grind/tamp issue, not a problem with your machine.
这个答案有帮助吗?
得分 3
2条评论:
Yes, remove the shower screen and CLEAN the group head and the screen.
I did not see this in the instructions, so this task is likely missed by many.
I had one machine where there was sooooo much coffee residue behind the showers screen that NO water could get through. And every hole in the shower screen was plugged. Gave it a good cleaning and it worked fine.
完成的
Had the same problem, after much stripping and experimenting it turned out that it was the grinder getting clogged and therefore grinding too fine. All sorted now 👍
完成的
添加一条评论
This unit is likely the same as the Rio Vapore - HERE is the manual
Page 28 - troubleshooting may assist
These iFixit Starbucks Barista Guides may be useful too!
HIH
这个答案有帮助吗?
得分 1
添加一条评论
It has happened to me and I went to several forums to try to fix it and it just wouldn't work. In despair I just used CLR, or a generic Calcium Lime and Rust cleaning spray directly on metal filter container and VOILA worked like a charm. I just sprayed the metal cup and inside the portafilter, let it sit for some 10 mins then rinse very very well. Unbeknownst to be, I have hard water and the little holes where coffee was supposed to go thru were clogged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
pavel zlatev 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 131
总计 47,125
