跳转到主内容
Repair guides and support for televisions manufactured by Panasonic.
576 个问题 查看全部
Panasonic TC-55CX400U black screen. Red led not blinking but solid red
My panasonic TC-55CX400U wont turn on. When I press the power button on the TV, I see the red power light on but the screen would remain black. The lights are not blinking. Note that I can use the remote to turn on or off the red light. I tried few of the troubleshooting (removed it from wall socket, put back, pressed power button for 60 seconds etc) but nothing happened. What could be the problem ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This has happened with mine too. I believe the LED backlight has failed. Apparently, if one or two LEDs stop working, the TV is programmed to turn them all off, possibly to avoid burning the rest of them out due to voltage imbalance.
这个答案有帮助吗?
得分 1
2条评论:
Same with mine. How can I swap the LED backlights out? Where do I order them
完成的
You can find some on eBay, this auction for example:
https://www.ebay.com/itm/183906148718
There are quite a few YouTube tutorials showing how to replace LED strips. Not necessarily for this model, but they all seem to be fairly similar construction. Still not for the faint of heart, though. I haven’t plucked up the courage to do mine yet.
完成的
添加一条评论
添加你的答案
Observer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 357
