跳转到主内容
A 64.52" LED 2160p 4K UHD Television released in 2015.
13 个问题 查看全部
must power cycle to get pix
VIZIO P702ui-B3 If off for more than a few hours the led (lower left corner) lights, Audio works, but no picture. If power cycled 2 or 3 time it turns on normally.
This happens with the remote or the manual switch on the set.
I’m thinking about replacing the power supply. Could that fix it or perhaps the Tcon board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I had a similar problem with my P55-C1 (audio, no picture). I used a flashlight and discovered that the picture was actually working but the backlights weren’t coming on. I replaced the LED driver boards (four of them) and now I have a working picture again.
这个答案有帮助吗?
得分 1
1条评论:
where do you find a driver board? Would you post a tutorial on replacing it please?
完成的
添加一条评论
添加你的答案
Greg “Bad Kitty” Arikian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 321
