跳转到主内容
加入维修社区 - 创建账户
适用于配备 GSM 3G 蜂窝网络(AT&T)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。采用双核处理器。于 2011 年 3 月发布。通过型号 A1396 进行识别。维修时需要使用加热工具并小心撬开。
Can I swap the eMMC chip from an iPod touch 5th generation.
Hi,
I have an iPad 2 GSM which doesn’t seem to turn on, that is it just shows the Apple logo and then nothing else.Tried restoring it with iTunes but the restore doesn’t complete and I get an error.
When I took it to a repair shop they figured out that it was caused by the eMMC and that they don’t have replacements.
I also happen to have an iPod touch 5th gen which also has the same processor and such as the iPad 2.So i was wondering if its eMMC could be swapped with the iPad.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
There is no eMMC module in either the iPod's or iPad's or iPhone's
Apple uses custom flash chips.
完成的
添加一条评论
2个答案
已选择的解决方案
Replacing a NAND IC on the iPad 2 is doable but as Dan mentions, it requires a special programmer and micro-soldering skills. I don't know if the iPod Touch NAND IC is compatible or not but functionally speaking, compatible NAND’s are available via Chinese vendors.
The question really becomes wether you’d want to spend the money to have this done to an older device like an iPad 2. It would certainly be much cheaper than the prices quoted in Dan’s answer but IMO, still expensive in relation to the value of an old iPad.
这个答案有帮助吗?
得分 3
添加一条评论
Swapping chips around is not something I recommend, Unless you really know what you are doing and have the proper equipment (only pro’s have the needed skills & gear). Even still these devices use special software that prevents swapping out the flash chips alone. Basically, just not doable!
Just review the IFIXIT teardowns:
iPad 2 GSM图片
指南
iPad 2 3G GSM 和 CDMA 拆解
难度:
中等
iPod Touch 5th Generation图片
指南
iPod Touch 5th Generation 16 GB 2014 Teardown
难度:
中等
这个答案有帮助吗?
得分 0
8条评论:
So even if the chips where swapped successfully by a pro,it won’t work?
完成的
The cost factor and risks doesn't make it worth the effort. Are you going to spend $300 ~ 500 to do this?
Remember! You need to swap out more than the one chip and because of the big differences between these devices the pre-loaded OS is not even compatible across them. And besides the flash chips are not the same.
完成的
Hey Dan, a NAND swap would be much cheaper than this (although still not worth it IMO) and the IC is fully formatted prior to installation. iTunes automatically installs the appropriate iOS version when the device is initialized.
完成的
A point I think got lost here is the chip used in the iPad is a combo chip NAND/RAM unlike the iPod which is a NAND.
完成的
That's not what the schematics say, they both use NAND Flash IC's. The A5 SoC is a layered CPU/GPU & SDRAM.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
SamStar Creative 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 935
