跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Unable to Eject SIM Tray
iPhone 7 Plus SIM tray will not eject using a SIM card eject tool or a paper clip. Applying a considerable amount of force does not produce any indication that the tray will eject.
The tray is flush with the device and there is no bend to the device body.
Paperclip can be inserted ~4x further into the SIM tray eject hole when compared to an iPhone 7 with functional SIM tray ejection.
I see there is a SIM Eject Lever Replacement guide for the iPhone 6, but it is not clear to me if the same guide would be applicable for the iPhone 7 Plus.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
To me it sounds like your iPhone 7 card spring is stuck in the eject position or broken. Broken doesn’t seem right to me, because those levers are metal. But to reset the card spring, you would need to open the device. Having the device opened and taking a picture of the sim card spring would help with this. Do you think you’re able to do that? Only reason is because card spring can’t be fixed from the outside, and getting a visual on the interior will allow us to know what may be the issue. Going to try and find a tutorial for you, because the 7 is pretty different from the 6.
Update: Im trying to find a tutorial, but I can’t find one.
Now that I think of it, there can be a few things wrong, but only one is your issue, but first let’s just see what the pictures look like from the top side of the board without removing the logic board.
iPhone 7 disassembly guide: iPhone 7拆解
Note: stop at the end of step 6 then take a picture
这个答案有帮助吗?
得分 2
2条评论:
Thank you for answering.
There is a SIM currently inside the device and I need to replace it.
Step 11 of the iPhone 7 (not Plus) teardown guide gives an idea of how the eject lever works:
iPhone 7拆解
Update:
Thanks again. I will post the pictures here when I have taken the device apart.
完成的
Ok awesome! Going with an Apple authorized service provider is not a bad idea. Also the 7 Plus tutorial is one of the worst tutorials on here, so stick with the 7 tutorial only for better explanation and pics. If you have questions, feel free to ask them and i'll be here.
完成的
添加一条评论
添加你的答案
William 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 8,069
