跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Rebooting after battery replacement
Hey,
I replaced the battery of an iPhone SE about two weeks ago. The iPhone worked great after replacement. But now, after two weeks of use, the iPhone wont boot to homescreen. Its stuck at the Apple logo.
What Ive down to repair it: I have set the iPhone in recovery mode and tried to reload and install iOS 12. But now the iPhone starts, display shows the Apple logo, turns off, and starts again. I also tried older os versions but still the same.
Can anyone help? Could the new battery be the problem?
Thank you!
Christian
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
test the battery, use a multi-meter and connect to battery, if the reading drops quickly it is the battery, V reading should hold for a bit if it is good. Try another battery.
完成的
添加一条评论
1个答案
已选择的解决方案
I would certainly suspect the battery, it is the weakest link in the chain.
If you still have your old battery and it still worked, I would try installing it to see if the problem goes away. If you have access to a multimeter, you could also measure the voltage directly on the replacement battery to see if it is charged or not. A phone should boot with a battery as low as 3.2V, maybe even a bit less. If you have less than 3V, then either your battery is bad or there is an issue with the charge circuit (cable, brick or logic board).
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 101
