跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Uniden phones.
Handset doesn't charge battery or work
On returning from holiday the handset and charge base were on the floor having been knocked over by cleaners.
The handset doesn’t charge on the original base or any of the other 2 bases I have. The battery works normally however, in the other 2 handsets.
I have also tried tried my other 2 batteries in the dead handset with no result.
In summary all three batteries are in working order but none of them can operate the dead handset.
Is repair needed and/or possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @gld ,
What is the model number of the phone?
完成的
添加一条评论
1个答案
You could potentially have broken solder points where the battery terminals connect to power the phone itself. You could open up the phone, which are fairly easy to do as they are typically a single board with two screws holding the case closed and you can then pry the rest opening. Check the solder points on the battery terminals, it they are loose or missing you may be able to repair it by resoldering the points.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Deacon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 150
