跳转到主内容
White screen with lines
Hi, my Toshiba Satellite C55D-B5308 laptop fell off my bed and it started to display colored horizontal lines:
I turned it off and on again and it changed to a solid white screen with really-hard-to-see vertical lines.
The LCD is not cracked (I flashed a light while it was off and didn't notice any broken pixels) and flexing the upper chasis does not change the pattern.
I disassembled and reconnected the display ribbon cable, pushed the CPU a little bit, reseated RAM and also checked if the cable inside the LCD panel was connected correctly (it was, I reseated it anyway)
None of this fixed anything. I must note that it turns off automatically and connecting to an external display does absolutely nothing. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Does it do this the second you power it on, or does it post at all.
完成的
I turn it on and this happens immediately, it's not a software issue, also the lines don't move and the color doesn't change. (The lines can be seen if you look at the screen in a certain angle)
完成的
Miguelito, What does that text say on the screen below the coloured lines?
完成的
添加一条评论
1个答案
已选择的解决方案
That can be a number of things. Unfortunately unless you have other similar laptops for testing, the only way to troubleshoot is to spend money on parts. I’d start with the motherboard as that’s the most likely. If that doesn’t fix it, try the screen (make sure the inverter is built in). I would also replace the LCD cable since it’s so cheap. Good luck! If you do have test laptops, I’ll gladly help you troubleshoot.
这个答案有帮助吗?
得分 2
2条评论:
That's definitely the screen then. Replace the lcd screen and you'll be fine.
完成的
添加一条评论
添加你的答案
Miguelito G. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 4,145
