跳转到主内容
Repair information and support for the Samsung Notebook Series 9 15" laptop. Released in 2012. Model number: NP900X5L-K02US.
6 个问题 查看全部
I´ve a vertical white line in the screen that appear after my lapt hit
Hi Guys
My laptop was running out of thermal past and because I have it always on at home but I don´t use it very often, I didn´t realize about it, I only saw it one day that it just turned off running super hot.
I´ve open it, I put thermal past in the CPU and it works very well again, except for one very samall detail, a white small line appear in the screen and I´m not sure how to solve it, because I´m afraid that the display is fine, but eigther a connector or the video card can be damaged due to the high temperature.
I appreciate any help.
Thanks,
Mauro.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @mruizdia ,
Connect an external monitor to the laptop and check if its' display is OK.
(even a TV can be an external monitor if you have the correct cable and the TV has the appropriate inputs)
If it is OK then the GPU is OK and the problem is either with the LVDS cable or the LCD panel.
You did disconnect the battery after you opened up the laptop and before you worked on the repair, didn't you?
这个答案有帮助吗?
得分 3
添加一条评论
The video chip may have a bad solder connection. Take a fine magnifying glass to it, and check for blackened or corroded contacts. If there are any, clean it off, use flux and a nice hot soldering iron, and apply a little solder to it. The LCD connector may also be faulty. Check on that too.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mauro Ruiz Diaz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 769
