跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s not turning on after DIY repair
Dear ifixit family,
I have a dead iphone 6s that I tried to repair myself, my first dead-phone repair.
The initial problem is the phone turn off by itself and won’t charge or reboot. I tried to reset it (power+home button combo) but no luck. What I found is that the phone is undetected by the itunes.
My first try is to replace the battery but still have no response. I thought the battery is flat so I charge it separately and put it back but it still not turning on.
As the battery is fine and with charged battery it still not turned on or detected on itunes, I suggest the problem is board level. So I try to replace it. But again, it’s not working with the same issues (not turning on. not charging, undetected on itunes).
So I run out of ideas now and need some help, anything that I should try? I really want to fix this phone .
Thank you.
P.s. I think I will try to replace the lightning port. I will update the results.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
if the phone turned off by itself then its probably a logic board issue and changing the charge port wont fix it
这个答案有帮助吗?
得分 3
4条评论:
Thank you for the quick response. I did try to replace the board with a tested good board, but the issue persist. What do you think?
完成的
Do a bare-bones test which is basically unplugging all non-major components such as the front camera, home button interconnect cable (The one coming from the screen not the button).
See if it can turn on, you can also try switching on without a screen if you want.
完成的
Thank you Ben for your response. I have tried to do a bare-bone test for every combination of components including camera , screen, ports, even wifi antennas but it still can't turn on. I guess there are multiple components failure that makes the phone refusing to boot properly, or maybe even the cables. There are nothing left to do then.
完成的
Chris Dan if you have a multimeter check vcc_main. You should find helpful videos on you.
完成的
添加一条评论
If you’ve not tried a new charging port that would be my next step
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 108
