跳转到主内容
HP Elitebook 6930p announced in September 2008 and was one of the first generation EliteBook laptops. It was advertised as the first laptop to break the 24 hour battery life barrier.
18 个问题 查看全部
How do I go about replacing the screen of my device?
My elitebook screen broke few years back and I gave up on the thought of fixing it because previously the battery,speaker,keyboard and touchpad had all gone faulty. I had to add a lot of externals to use it but the screen getting broken was just the last straw.
Recently however, I decided that I'll need to repair this pending when I can get a better one. I want to fix it myself and the screen seems like it may be my biggest challenge yet. Please help. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @osazeyyh ,
Here’s a link to the service manual for your laptop.
Scroll to p.85 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
Also on p.85 you will find the part numbers for the various displays available for the laptop.
If you search online, typing the part number only (appropriate to your particular model variant) in the search box of your browser, you will get results for suppliers of the part. If you wish to verify that you have the correct part number it is usually stamped on the back of the display panel.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
1条评论:
Thanks so much! I'll go through the service manual and see what I can do.
完成的
添加一条评论
添加你的答案
Osaz Eyyh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 71
