跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
20 个问题 查看全部
Pixel 2XL display dying pixels.
I’ve had this new screen and digitizer applied to my Pixel 2 XL and not white lines are covering the right side of the screen completely. [See Images] Any suggestions on a fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
12条评论
Is there any water damage to your phone? If not, please request a new screen as this seems like nothing but a broken part.
完成的
I don't know, it's hasn't been near water recently but that can be a cause?
完成的
where can i get new display for my pixel 2 xl
完成的
Please was the lines there before you changed the screen, because the lines just appeared in my 2xl while I was watching videos. Please I need a solution
完成的
@itua was the phone overheating?
完成的
显示更多的7条评论
添加一条评论
1个答案
已选择的解决方案
Hi,
How long since the screen and digitizer were replaced?
If not long ago (<30 days) and it was done by a reputable repair service, take it back and show them the problem. They should provide some sort of guarantee on their work.
It may be a faulty screen which is not their fault but they should still repair it again. They would want to know about it if they were getting faulty parts from their supplier.
If you did the repair yourself (or it was done by a friend), contact the supplier of the parts and ask them about getting a replacement screen and digitizer.
这个答案有帮助吗?
得分 2
2条评论:
It wasn't repaired by a service I did it myself at home and I made sure to be extra careful during install. I purchased it with the tool kit for fixing phones that ifixit has and I used a heat gun that I have at home. So you're saying since I did it myself I should contact ifixit and issue an RMA to get a replacement?
完成的
Hi @lunaluvli ,
If you purchased the screen from ifixit, contact them about the problem
https://help.ifixit.com/article/49-retur...
完成的
添加一条评论
添加你的答案
Rose Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,484
