跳转到主内容
2006年十月在北美发布(然而2021才翻译。。15年的坑)
289 个问题 查看全部
What happens if you plug in a 110v wii into 220v?
I have an American Wii, its 110v and I moved to Saudi Arabia and I accidentally plugged it in without a converter. It made a lot popping sound and even when I plug it in a 110v converter it would not work so I opened up the power brick and saw some small yellow stains on the board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
When you connect a device to a voltage higher than it’s rated supply voltage, it over-stresses the circuit inside the device. By doubling the voltage from 110 upto 220V you have also forced through much more current into the device. Chances are that 2 x voltage blew some components inside before the excess current would have over- cooked the the circuit inside. If a component has stained the board, chances are that’s what got stressed and broken down inside. The yellow stains maybe insulation from a component or transformer indicating the defect component. An electronics repair shop maybe able to help or seek out a replacement power brick? Hope this helps?
这个答案有帮助吗?
得分 1
1条评论:
My cousin used to burn out her American hairdryers on UK mains supply all the time until she bought one specially to use in the UK and Europe.
完成的
添加一条评论
添加你的答案
yusuf ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 2,552
