I can hear the laptop works but nothing shows on display
Hello, I have am Acer Aspire 5740G and when I power on the laptop I can hear it work but it doesn’t show anything on the display. I connected the laptop with hdmi on my monitor and the monither show “No signal”. Is there any way to check if the problem is from GPU or from Screen?
Hi,
Just checking that you pressed Fn +F5 to toggle the display between the internal, external and both screens on together to see if you get a display anywhere?
If you don't get a display at all, then you have a GPU or motherboard problem
由 jayeff 完成的
@jayeff I am the same guy you are speaking with the Sony Vaio, I have the same problem here. But this laptop does not have a flickering screen. It doesn't open at all.
由 Savvas Giannoukas 完成的
Hi,
OK
Same deal with display or not in BIOS
If there is a display in BIOS try starting the laptop in safe mode and check if the display works.
If it does you have a driver problem or startup problem.
If there is no display in BIOS or safe mode here's a link to a video so that you can check the LVDS cable connections etc, as per the other answer
由 jayeff 完成的
