跳转到主内容
Certain Keys not Working
I’ve received a Mid 2010 13” MacBook Pro from a friend, and the 7 key seems to not work.
I was wondering what you’d recommend trying before replacing the keyboard assembly.
I was also wondering if the keyboard for a Mid-2012 MacBook Pro of the same size would connect to the logic board, as they have the Launchpad key, instead of the dashboard key, and that’s what I prefer.
Thank you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Switching out keyboards won't alter the keys function. It's the programing of the keys assignment. Go to the Keyboard control panel and click on the Shortcuts tab. You can set the Fn keys to what you want.
完成的
Thank you for that!
完成的
添加一条评论
1个答案
已选择的解决方案
Here’s the needed part MacBook Pro Unibody (A1278) Keyboard
Here’s how to do it: MacBook Pro 13" Unibody 中期 2010 键盘更换
MacBook Pro Unibody (A1278) Keyboard图片
产品
$19.99
这个答案有帮助吗?
得分 3
3条评论:
Thank you for that, although I was hoping for recommendations before replacing the keyboard assembly, since I don't want to go that deep into a repair if it could simply be resolvedly cleaning underneath the key, for example.
完成的
Sorry, no magic here a bad key is often corrosion damage from a liquid spill. You'll need to fully remove the keyboard to get to the point you can clean the spill and fi even possible patch the line thats bad. Are often the break is within the switch blister which you can't get into without killing it, hence the need for a new keyboard.
完成的
No problem, just thought I'd ask.
Thank you for your help
完成的
添加一条评论
添加你的答案
Koston Morin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 271
