跳转到主内容
Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
Upgrade OS to High Sierra?
I have upgraded to El Capitan, but would like to know if the model could be upgraded (clean install) to High Sierra or perhaps Sierra? According to the spec’s listed for the OS X High Sierra, this model should be able to be upgraded to High Sierra.
If it is not able to be upgraded, could you elaborate on why it would not be able too? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The Core 2 Duo based systems are not able to run 64bit apps natively.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
High Sierra and Sierra both require a Late 2009 or newer model iMac. Yours is a Mid 2009 model so it cannot run either.
这个答案有帮助吗?
得分 1
4条评论:
Slight correction The highest is El Capitan OS-X 10.11.x
iMac "Core 2 Duo" 2.26 20-Inch (Mid-2009)
完成的
Oops. Edited.
完成的
Is this a limitation of the processor? If a new SSD hard drive were to be installed, would that make a difference? Thanks!
完成的
The CPU is the issue not storage. But! Putting in a SSD will improve performance! iMac Intel 20" EMC 2266更换硬盘指南
I would also max the RAM to 8 GB. iMac Intel 20" EMC 2266 RAM Replacement
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 830
