跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
Can I swap out the hard drive for one with windows already on it
I have a 1 tb hard drive from a windows laptop I had that died and I have an old iMac from a family member that doesn’t need it anymore can I swap the hard drive so I can run windows instead of OSX.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
First the drive will need to be a 2.5” to fit inside and support the newer version of S.M.A.R.T
As for running Windows only after you’ve installed BootCamp under MacOS will you be able to then install Windows. Here’s a good guide on how How to install Windows on your Mac using Boot Camp
So, if you where trying to save whats on the drive that won’t work.
这个答案有帮助吗?
得分 2
添加一条评论
Short answer, probably not. The drive would have to be formatted as GPT; if the donor Windows machine was a UFEI system then you MIGHT be able to boot from the drive. You can try connecting the drive to a USB adapter and seeing if the Mac will boot from it. If it shows up as a boot device then it's GPT.
However, even if you can boot into it you'll need a Windows license key and Apple's Boot Camp drivers for the hardware. If your Mac is running OS X now that second part shouldn't be a problem; just run Boot Camp Assistant and make a USB drive with the drivers on it.
Personally, I'd just swap the hard drives, reformat, install OS X, then use Boot Camp Assistant to make the smallest possible/practical OS X partition, then clean-install Windows onto the other partition. Least amount of question marks there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
superfudge03 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 129
